Is there ever going to be a release of the SDK for K60F/K20F that is compatible with the MCUExpresso tools?
michaelcollins
 We have developed a software framework that targets the SDK and will be using several chips including the K20F due to none of the other processors meeting our needs and would like to be able to not change the common framework.
danielchen
Hi Michael:
Unfortunately, currently no plan to support K60F/K20F.
michaelcollins
Where can we get some documentation on how to create an SDK that is compatible with MCUExpresso and its tools?  I had a port to the SDK2.0 tools that worked with KDS but it does not work with MCUExpresso.
danielchen
Here is one document  MCUXpresso IDE User Guide.pdf, it seems relevant to your requirement.
It is under your MCUXpresso installation folder.
Chapter 6  Creating New Projects using installed  SDK part support.
