Is there any way to generate 1Mhz clock on K66 using timer?
karthikpoojary
In K66 is it possible to generate 1 Mhz clock using timers? I have created a software based clock using a timer interrupt but is it possible to generate without having to toggle the GPIO pin in software?
mjbcswitzerland
Specialist V
You can use any TPM or FlexTimer to generate frequencies or PWM signals:
HW timer guide: http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
Mark
Kinetis: http://www.utasker.com/kinetis.html
Kinetis K66:
- http://www.utasker.com/kinetis/TWR-K65F180M.html
- http://www.utasker.com/kinetis/FRDM-K66F.html
- http://www.utasker.com/kinetis/TEENSY_3.6.html
Free Open Source solution: https://github.com/uTasker/uTasker-Kinetis
Working project in 15 minutes video: https://youtu.be/K8ScSgpgQ6M
For better, faster, cheaper product developments consider the uTasker developer's version, professional Kinetis support, one-on-one training and complete fast-track project solutions to set you apart from the herd : http://www.utasker.com/support.html
