Is there any way of securing jtag connection with KW41Z ?
822件の閲覧回数
satsok_n
I am using KW41Z on a freertos project. Is there any way to use any kind of authentication on the connection with jtag (maybe a password). The main goal is to create an access control on jtag connection.
768件の閲覧回数
estephania_mart
Sorry for the inconvenience this might cause you but the KW41Z supports only SWD protocol, not JTAG.
If you want to protect the memory, you can check the Chapter 9 Security of the reference manual of the KW41Z. Also, you can check this application note and use it as a base to understand the basic functionality of the registers .
Hope this helps.
Estephania
