Is the ARM D-Stream probe supported on the K60-120?
Larry5335
Including full trace capability and any required stationary and/or init files?
Tags (4)
Kan_Li
It supports all cortex-M device, but as I know, there are two types of license , one for all ARM core, and the other just for I.MX, so if you want to apply it on K60-120, you might have to buy the license for all ARM core.
Hope that helps,
B.R
Kan
