Interfacing 16-bit SDRAM on K65
998件の閲覧回数
anton_svensson
I'm having problems interfacing a 16-bit SDRAM on the k65.
The SDRAM being used is an MT48LC4M16
The SDRAM is connected as in the picture attached.
The problem I get is when I try to access the SDRAM, with an 32 bit access not with 16 or 8 bit, and writing the prechargeall command I get some sort of exception and landing at 0x10066958.
When accessing with 16/8 bit I won't get any information to the SDRAM, writing and reading all result in 0x0 in values.
Anyone had similar problems?
Anton
Original Attachment has been moved to: Sdram.cpp.zip
タグ(2)
4 返答(返信)
666件の閲覧回数
Masmiseim
Senior Contributor I
Hey,
i think you have a  timing mismatch between the controller and the SD-RAM. This is not setting a CAS-Latency of two:
bP = (UINT8 *) (SDRAMADDR + 0x20);
Try 0x400 instead.
666件の閲覧回数
anton_svensson
Hi Markus!
I tried you're idea and it didn't change anything.
When looking in the reference manual for the SDRAM I get that the CAS-latency is set on A6-A4, so 0x20 would refer to A5 and CAS = 2.
But I'm thankful for the tip!
Anton Svensson
666件の閲覧回数
xiangjun_rong
Hi, Anton,
Can you refer to the documentation and code based on K65:
How to access SDRAM based on K65 SDRAM controller
Pls refer to the code, if you still have issue, pls update here.
Xiangjun Rong
666件の閲覧回数
anton_svensson
Hi!
I've used that documentation and code as an example.
The weird behaviour I have at this point is that it seems that I can write to the lowest bit when accessing as a 16-bit device through the SDRAM controller. However it seems like I only can access one adress.
A write of 0xFFFF will result in a read of 0x1.
A write of 0xFF0 will result in read of 0x0.
If I try it as a 32-bit device in the controller, I can write to the lowest 16 bits, but still only on one adress as it seems.
A write of 0xFFFF will result in a read of 0xFFFF.
A write of 0x1234 will result in a read of 0x1234
Anton Svensson
