Using the serial current limited resistor is not robust for the KL03 pins with 5V input.
The KL03 pins are 3.3V tolerance.
Customer need to keep KL03 pins input voltage below datasheet shows Max. 3.6V .
Thank you for the attention.
Wish it helps.
Ma Hui
