IEEE802.x.x on K series MCU
284 次查看
sajeshsf
We are evaluating the scope of implementing IEEE 802 standards in our system over both Wi-Fi and Ethernet connections. Ours is a multi-board system based on K60 and K66 controllers. We are also using WolfSSL and mbedTLS for various security needs.
Does mWX support IEEE 802? What would be the recommended steps from NXP for implementing this?
标记 (1)
264 次查看
Celeste_Liu
Hello @sajeshsf ,
Thanks for your post.
I'm not quite sure what "mWX" you mentioned is. Could you help to explain it?
BRs,
Celeste
