I want to know can I use 16 bit ADC channels as single ended input in Kinetis K22.
1,340件の閲覧回数
pushpraj
1,335件の閲覧回数
myke_predko
Senior Contributor III
Hi @pushpraj
Yes you can.  Look at the "ADC# Channel Assignment for..." table in the Reference Manual of the device you are going to use.
It will have the channel number for the ADC#_DP# pin (the positive input pin of the differential channel) and note you have to set the DIFF bit to zero.
I highly recommend that you tie the DN# input to ground when you're using the DP# pin as a single channel.
myke
