Code is attached
Original Attachment has been moved to: SPI.c.zip
Original Attachment has been moved to: main.c.zip
The initialization of SPI0 module pins and clock seems right. One problem can with the comparison in register_write()
if(SPI0_S == 0x20)Instead of this comparison, try:
if((SPI0_S & 0x20) == 0x20)(Because other bits in SPI0_S like SPRF, SPMF can also be 1. Then SPI0_S may not be 0x20 always)
Good luck
