I'm trying to get the slcd working on my twr-k53n512 board. I upgraded the Code Warrior license which downloaded the proper pe micro components. The board does NOT alternate the 28 segments - only the logo is lit.
Search instead for
jamescassese
Could a jumper setting be wrong?  I checked several times and changed Jumpers 32 and 33 to 1-2 for connection.
jamescassese
Thanks, Mark.  I'll give it a check.  Jim.
mjbcswitzerland
Specialist V
Try a binary from here to check the HW:
http://www.utasker.com/kinetis/TWR-K53N512.html
Check SLCD details at http://www.utasker.com/docs/uTasker/uTasker_SLCD.pdf
See examples in video:
https://www.youtube.com/watch?v=nm2DmZv1rj8
Get complete open source solution with SLCD emulation built in at
http://www.utasker.com/forum/index.php?topic=1721.msg7086#msg7086
Mark
Professional support for Kinetis: http://www.utasker.com/index.html
Remote desktop one-on-one coaching: http://www.utasker.com/services.html
Getting started to expert videos: https://www.youtube.com/results?search_query=utasker+shorts
