I am new to work on this chip and I would like to get some help. Manufacturing part number is
MK60DN512ZVLQ10
yes you can use these pins as GPIO. You can set the GPIO pin configuration for each of pins (OUTPUT, INPUT) with all appropriate feature as pull-up etc.
