Https Client
Https Client
2,414 次查看
a8Chcx
I am using https client to talk to Https Server, it works fine. I have the following questions:
When I communicate with https server, it will take around 1s to negotiate with server, then I can send request to server, get the reply form server.
My question: Can I just do negotiation once, then keep sending request and getting reply every second for saving time?
Christie
2,403 次查看
Pavel_Hernandez
​​​​​​​Could you tell me what device are you using? I suggest reviewing the connection for WebSocket this session persistent connection between a client and server. If you need more information please let me know.
2,395 次查看
a8Chcx
Hi Pavel,
Thanks.
I am using FRDM-K66 with MbedTLS. The server is the device from other company...
I am just wondering if it is possible to keep http or https connection ON and keep sending and receiving from server because https negotiation take lots of time? Need to do something on server side as well?
Christie
2,348 次查看
Pavel_Hernandez
Does this issue persist if you use another device? Maybe 1s to negotiate is the capacity of the server, is this service is free?.
