How to use two kbi0 pin inKEA128
xiaohui200808
Hello
    Now  I use KEA128,I use  two kbi0 pin to wake up mcu。but It donot work 。when I use  one kbi0 and one kbi1 ,the two pins all can wake up mcu ,but when use two kbi0  pins ,the interrupts not happened .Could you help me,give me some demo。
 Thanks!
victorjimenez
When you use two pins from KBI_0 neither of the interrupts happen? Could you please provide me your code so I can reproduce the behavior you mention to see what is causing it.
Victor.
