How to use the internal 1.2v reference for ADC on K60 ?
1,476 次查看
danielchai
Senior Contributor I
Hi All,
I am using the MQX10.4 and MQX4.0.1.
I was trying to use the internal 1.2v reference for adc0.
I used ioctl(adc_dev0, ADC_IOCTL_SET_REFERENCE, ADC_REF_VREF), but when I check the register SC2 reference bits still shows 00.
I also tried to manually set the VREF_SC  and SC2 register.
VREF_SC |= 0xA0;
ADC0_BASE_PTR ->SC2 |= 0x01;
but the reading result still based on VREFH and VREFL not based on internal 1.2v.
Any suggestion about this?
Thanks.
1,187 次查看
danielchai
The ADC_REF_VREF does not work. But change it to ASC_REF_VALT, IT WORKS.
1,188 次查看
danielchai
1,187 次查看
DavidS
Hi Daniel,
Sorry for trouble but very glad you resolved it.  Good debugging on your part.
There is also Freescale AN4568 that uses internal voltage reference for Kinetis K series that might help others.
David
