Hello
I am a newhand, how to transplant FATFS to K60 microcontroller in CW environment, it is best to use PE.Looking forward to your reply, thank you very much.
解決済! 解決策の投稿を見る。
Marks solution is a good one.
If you want to use PE, I wrote an article about that subject here:
FatFs with Kinetis | MCU on Eclipse
The projects are available on GitHub: mcuoneclipse/Examples/CodeWarrior/TWR-K60F120M at master · ErichStyger/mcuoneclipse · GitHub
I have attached one project for CodeWarrior for MCU 10.x with FatFS to this reply.
It uses some extra Processor Expert components, see McuOnEclipse Components: 1-Apr-2018 Release | MCU on Eclipse for the latest release and installation instructions.
I hope this helps,
Erich
Try one of the following:
http://www.utasker.com/kinetis/TWR-K60N512.html
http://www.utasker.com/kinetis/TWR-K60D100M.html
http://www.utasker.com/kinetis/TWR-K60F120M.html
There is "turn key" SD card (and memory stick) FAT file system operation (valid for just about all Kinetis parts) on SDHC or SPI in the uTasker project.
utFAT has more features [http://www.utasker.com/docs/uTasker/uTasker_utFAT.PDF] and if you enable the TCP/IP stack (processors with Ethernet or USB [RNDIS]) it immediately allows FTP and HTTP operation from the SD card too.
Don't panic - it is also free and open source (and includes CW project target)!
Mark
uTasker - for more performance and faster, cheaper product development
I hope this helps,
Erich
