How to set TSEG1 and TSEG2 in register CANBTR1 of KEAZ128?
1,186 次查看
w_lingjun
Hi, I'm studying on the MSCAN initialization based on KEAZ128. When I set the register MSCAN_CANBTR1, there are three parts should be set. I don't know how to set the TSEG1 and TSEG2, the reference manual only list the value they can set, but not introduce how to set these two values. For example, the TSEG2 can be set from 001b to 111b, it is only a range, which value should I set? Waiting for your reply. Thank you very much! Best regards, Sarah
1 回复
1,182 次查看
kerryzhou
Hi w_lingjun
  You are from China, so you can refer to this document, it will help you understand the TSEG1 TSET2 configuration:
https://www.nxpic.org.cn/module/forum/thread-599175-1-1.html
Wish it helps you!
Best Regards.
Kerry
