How to set CAN rx filter
1,428 次查看
JungkyuHan1
Using KW38
I want to make a CAN RX filter
ex: 0x18FFB034 ~ 0x18FFB534 , 0x19FFB028
Please Guide me.
1,367 次查看
EduardoZamora
Hello @JungkyuHan1
CAN controller affiliated with each node implements a filter that checks the arbitration ID of a broadcast message and either accepts messages when the arbitration ID is within a particular range, or ignores messages outside of that range. Matching to a range of IDs should be possible by using ID acceptance masks. FlexCAN supports individual masking per MB (IRMQ bit set) or global masking scheme (IRMQ cleared).
Although there may not be specific documentation for this scenario, I will recommend you checking the MCUXpresso SDK API Reference Manual_MKW38 included in KW38 SDK documentation > docs folder. Chapter 14 describes the peripheral driver for FlexCAN module; please refer to "Configuration" APIs.
Just for reference, you can take a look at the Controller Area Network (CAN) standard - NXP Community.
Eduardo.
1,352 次查看
JungkyuHan1
[Shelf Solved]
need 1bit shift toward register.
base->RXFGMASK = 0x10FFB034<<1;
1,368 次查看
EduardoZamora
Hello @JungkyuHan1
Eduardo.
