How to perform floating point math on M0+ based KL16?
akashshah
The processor doesn't allow me to do any math with floating point value, Is there is anyway that I can make calculation using software?  grushbrush‌ michaelgoudey‌
mjbcswitzerland
Specialist V
If you enable FP library support in the tool chain you will be OK (it will just be quite a lot slower than on a processor with HW FPU.
Eg. in KDS
Mark
akashshah
Hi Mark,
Thanks for response, How can I add this library into my current project in KDS?
Akash
mjbcswitzerland
Specialist V
Akash
Just click that button - there is usually nothing more to do (as long as you haven't disabled the use of default libraries, in which can you can remove the linker option "-nodefaultlibs").
Mark
