How to make the KL26 MCU BCP bit work?
1,106 次查看
2743294708
Dear,
   When the BCP bit of I2S register TCR2 of KL26 MCU is set, it is expected that "Bit clock is active low with drive outputs on falling edge and sample inputs on rising edge". But I found that doesn't work. It menas the I2S SCLK doesn't change when the BCP bit is set or not.
   Plear help to confirm how to make the BCP work.
标记 (4)
4 回复数
993 次查看
kerryzhou
Hi Max,
    Do you debug your code and check the BCP bit, whether it is really changed to 1 or not?
    Besides, could you also share some test result about your issue?
Kerry
993 次查看
2743294708
Hi Kerry,
   Thanks for your reply.
   I have tried several times, but all failed. Data is sent on rising edge.
   The code is like this.
    I2S0->TCR2 |= I2S_TCR2_MSEL(1) | I2S_TCR2_BCD(1) | I2S_TCR2_DIV(5);
    //BCP = 1: output on falling edge, input on rising edge
    I2S0->TCR2 |= I2S_TCR2_BCP(1);
993 次查看
2743294708
The TCR2 Value printed in log is:
TCR2 = 0x7000001.
993 次查看
2743294708
Dear Kerry,
I have another question about I2S. What is the meaning of the sentence highlighted in YELLOW color?
To avoid FIFO underrun, how to write the FIFO?
