How to describe 'naked' attribute function on IAR?
5,052 次查看
yasuhikokoumoto
Senior Contributor I
Hello IAR EWARM experts,
I posted this issue to the ARM Connected Community but have not been received any responses.
Therefore I would like to post to this site.
I would like to know how to describe a naked attribute function.
The code was compiled successfully with a standalone GCC but IAR GCC could not and display the following error messages.
エラー[Pe079]: expected a type specifier D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
エラー[Pe141]: unnamed prototyped parameters not allowed when body is present D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
エラー[Pe130]: expected a "{" D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
C/C++コンパイラ 実行中のエラー
Can anyone help me?
Thank you and best regards,
Yasuhiko Koumoto.
标记 (4)
3,810 次查看
mjbcswitzerland
Specialist V
Yasuhiko
These type of things are not standard and so are compiler specific.
You can use a define instead and declare the define according to the compiler used and then it is automated.
Mark
Kinetis: http://www.utasker.com/kinetis.html
For the complete "out-of-the-box" Kinetis experience and faster time to market
4 回复数
3,810 次查看
mjbcswitzerland
Specialist V
Hi Yasuhiko
Try the non-standard extended keyword __stackless
Mark
3,810 次查看
yasuhikokoumoto
Hi Mark,
thank you, the compilation was done successfully with __stackless.
However, the __stackless keyword was not accepted by the standalone GCC.
Is it IAR specific keyword?
Yasuhiko  Koumoto.
3,811 次查看
mjbcswitzerland
Specialist V
Yasuhiko
Mark
3,810 次查看
yasuhikokoumoto
Hi Mark,
thank you for good advice. I agree with you.
Yasuhiko Koumoto.
