How to configure Uart in KEA128
1,742 次查看
Abil
I am trying to configure Uart for kea128...set baud rate to 9600 ...and checking with tera term it doesnt showing any value..can anyone suggest how to configure it?
3 回复数
1,565 次查看
kerryzhou
Hi shweta,
  I have attached a kds PE project, it can printf the data with 9600 bps, I have test it on the TRK-KEA128.
  You can refer to it.
Wish it helps you!
Jingjing
1,565 次查看
Abil
hey thanks.....do u have any idea how to write LIN interface over Uart..am
using codewarrior10.6 with TRK-KEA128
On Wed, Aug 10, 2016 at 3:16 PM, kerryzhou <admin@community.freescale.com>
1,565 次查看
kerryzhou
Hi shweta,
    We have the LIN stack for your reference, please download it from this link:
http://cache.nxp.com/files/microcontrollers/software/device_drivers/FSL_LIN_2.X_STACK.zip?fpsp=1&WT_...
  After you install it, you can find the KEA LIN sample code from this folder: FSL LIN 2.x Stack Package 4.5.7\Examples\Kinetis\KEA128
Wish it helps you!
Jingjing
