How to change the clock freq of FRDM-KL05Z
zz642040273
I am using the MBED online compiler to program the MCU, but how do I set a lower clock frequency in order to reduce the power?
Best,
Zheng
ErichStyger
Specialist I
Hi @zz642040273
Not using mbed, but you can easily do this with the Freescale/NXP Kinetis Design Studio and Processor Expert in the Cpu and Clock settings:
You can easily configure all different low power modes and switch between them:
If using mbed, you can look at the code which is used for this.
I hope this helps,
Erich
zz642040273
Thanks, ErichS! I will try on it!
