Hello All,
I'd like to know how to configure CW10.1 to generate code that can exeute from FLASH. I am using the P&E multilink universal as my debug tool. I am able to build code that executes from RAM, however when the same code is built to execute from internal FLASH, I get invalid instruction error.
If you generate a new example project it will create targets for RAM an Flash that will essentially run. You can analyse these configurations and compare with yours that doesn't work correctly.
Mark
