How long to wait after configuring adc?
967 次查看
rickstuart
I'm multiplexing a processor pin between a digital-out (SPI/Clock) and an analog-in.  Every time I switch to the analog-in I make about a dozen test reading separated by 100ms.  Every time the reading start high and drop.  Not stabilizing for 3 or 4 reading.  That's 300ms to 400ms of waiting!  I scoped the processor pin and looked at many events.  The voltage during the analog-in phase is rock-steady-flat. That leaves the processor.
So, what's going on inside the processor?  Why does the processor's ADC feature take hundreds of milliseconds to stabilize?
-thanks
标签 (2)
标记 (1)
831 次查看
kerryzhou
Hi rich stuart,
    Thank you for your updated information, and that's very good to hear your problem is solved.
    If you still have question about this topic, you still can let me know!
Jingjing
831 次查看
rickstuart
The ADC was not initialized correctly.  Works good now.
