How can I configure the fatfs and Lwip stacks
1,608件の閲覧回数
juancarlosrome2
I would like to know How if it's possible set the fatfs to use the Lwip as a webserver but the web files stored in fat currently I couldn't get it working, I somebody has an idea pls let me know, thanks so much in advance,  I'm working with frdm k64
1,284件の閲覧回数
mjbcswitzerland
Specialist V
If you continue having difficulties you could simply use http://www.utasker.com/kinetis/FRDM-K64F.html
This has utFAT and the uTasker TCP/IP stack and the SD card or a memory stick can be automatically used by the web server and FTP.
http://www.utasker.com/docs/uTasker/uTasker_utFAT.PDF (see sections 8 and 9 for settings).
Available as open source at http://www.utasker.com/forum/index.php?topic=1721.msg7086#msg7086
Mark
Professional support for Kinetis: http://www.utasker.com/index.html
Remote desktop one-on-one coaching: http://www.utasker.com/services.html
Getting started to expert videos: https://www.youtube.com/results?search_query=utasker+shorts
