How Could I get BSP for Kinetis K70 ( TWRK70F120M) ?
ankurrahi
     I have BSP for Freescale P1025 TWR Board. I want to use Kinetis K70 for the same, for that I need BSP for Kinetis K70 (TWRK70F120M) TWR board. How could I get that BSP ?
I have attached the BSP for Freescale P1025 TWR board (bsp-freescale-p1025-twr.ifs)
     Any suggestion & Guidance are highly appreciated
     Thanks In Advance
Original Attachment has been moved to: bsp-freescale-p1025-twr.ifs.zip
ivadorazinova
Hi Ankur Rahi,
if you have board, which is not supported for BSP, find similar BSP, clone it and modify it.
We have created the tutorial for this procedure.
So, please take the similar BSP, e.g. for K60F and according to Getting Started with Freescale MQX RTOS BSP Cloning Wizard (which you find at C:\Freescale\Freescale_MQX_4_1\doc\tools) you clone your BSP
and according to MQX BSP Porting Guide http://cache.freescale.com/files/soft_dev_tools/doc/support_info/MQX_BSP_Porting_Guide.pdf you modify your BSP.
Iva
ankurrahi
Hi Iva,
       I m working on PLCs and wanted to make PLC using Freescale Kinetis K70 TWR Board, I need BSP in .ifs (installation file system) format for creating a PLC runtime environment on Kinetis K70 TWR Board. I am looking for the similar file I attached on my above post, that file is for Freescale P1025 which is not ARM based Micro-controller. I need for ARM Based Freescale Kinetis K70 TWR Board.
      Hope you got my query.
Ankur
Hui_Ma
I recommend customer to check with Freescale third partner QNX company about related Boot file containing PLC runtime environment (*.ifs) file.
More detailed info, please check below link:
http://www.qnx.com/partners/plc_reference.html
Wish it helps.
best regards,
Ma Hui
ivadorazinova
Hi Ankur Rahi,
Yes. Now I understand, you mean Boot file containing PLC runtime environment not Board Support Package from MQX. Excuse me for confusing information!
I will let you know.
Iva
