or any file that workes with Creo4
We don't have the FRDM-K66F board 3D model.
While, please check attached FRDM-K66F board Layout design file, which you could use Cadence software to generate the board 3D model.
Wish it helps.
Mike
could you provide a layout file that is compatible with Altium Designer? AD is not able to directly import a binary Allegro file (needs to be converted in Allegro to ASCII beforehand).
Thomas
Hi Thomas,
Sorry for the later reply.
We don't have the layout file for Altium Designer tool.
Really sorry for that.
Mike
