Has anyone tried to emulate CEC(Consumer Electronics Control) using GPIO?
2,115 次查看
koichimatsuo
About HDMI CEC
High-Definition Media Interface (HDMI) incorporates a single-wire interface called Consumer Electronics
Control (CEC) in order to support 'one touch' control features in newer audio/visual systems.
CEC is not a conventional bus and is not readily found on microcontrollers like the more common protocols I2C or SPI.
Currently TI is emulating this interface using GPIO.
Has anyone tried to emulate this interface using GPIO?
http://www.ti.com/lit/an/slaa377/slaa377.pdf
Koichi
标记 (1)
1,533 次查看
chetkaufman
I have a customer who also wants to control CEC line using a MCU GPIO line.    Can I have access to the answer that was provided to Koichi Matsuo?
1,533 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
michaelsteffenfae​  can you help Chester?
1,533 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
HI Koichi,
follow up will be provided in your internal post. I will close this  one.
