Has anyone seen and solved a Flexmemory partitioning failure?
718 次查看
StephenZavodny
Good evening,
I am using an 80-pin  K30 part with the Flex memory.  The project is using the Flex memory to store user preferences.  My initial prototype (software development buck) has this function working correctly with out any issues.  When I programmed the firmware into another prototype the firmware does not partition the Flex memory.  Each time I reset the CPU, the firmware acts as if the part is not partitioned, and writes to the Flex memory fail.  Has anyone else seen a problem like this?  Any ideas on how I can correct this problem?  I am using the IAR tool chain and the Segger J-Trace.
标记 (4)
521 次查看
vicentegomez
Hi Stephen
Have you check that there is not hardware issues on the board?
Can you load a simple project on the device? this is to check that you can program properly the device.
I hope this will you.
521 次查看
StephenZavodny
Good afternoon Pedro,
I was able to fix the problem.  I was initially specifying an incorrect partition size.
Stephen Zavodny
https://community.freescale.com/SmallSNTech Logo
321 Ley Road
Fort Wayne IN, 46825
Tel:  260-739-7002
Fax: 260-739-7122
Email: szavodny@sntech.com<mailto:szavodny@sntech.com>
URL: www.sntech.com
