Hard Fault after unlocking watchdog (KEA128)
1,338 次查看
pranav_prabhu
After coming out of stop, I am unlocking watchdog and reconfiguring it in the very next line. However, while unlocking MCU gets a hard fault. How do I prevent hard fault from occurring?
1,136 次查看
Hello @pranav_prabhu
Please do not set breakpoints when configuring the Watchdog. Run the program at full speed for testing.
Alice
6 回复数
1,266 次查看
pranav_prabhu
Hello @Alice_Yang
Currently when I try to put mcu in stop mode, it gets a hard reset.
1,313 次查看
1,309 次查看
pranav_prabhu
After waking up from stop mode, I need to configure the watchdog refresh again. At this point, I am getting a hard fault. This isn't seen when I configure before entering stop mode.
1,304 次查看
Thanks for your reply. I understand what you mean. Could you please first test by disabling the watchdog code after waking up from stop mode? Can it work properly then? We're doing this to narrow down the issue and confirm whether it's a watchdog configuration problem.
Alice
1,236 次查看
pranav_prabhu
Hello @Alice_Yang
I am in debug and put a breakpoint at the point where unlock is taking place. Is it because the clock cycles for unlock got elapsed.
1,137 次查看
Alice
