Getting "Write memory failed: address 0x0" error message
4,002 次查看
geochrist
Hi there,
We are getting a
Expected value:  0x1fffc420
Actual value:        0xffffffff
when trying to program a home made PCB that contains a MK40X512 device.  After this message, we get
[Chinese text] , A verify error has occurred while writing memory
We are using a PE Mimcrosystems USB Multilink Universal (RevA) (USB-ML-UNIVERSAL) programmer.
The programming succeeds when burning in the same program to a K40-KIT demo kit.  (This kit has
a MK40X256 in it, though.)
Has anyone seen this before, or does anyone have any ideas what might be going on?
Thanks.
George
6 回复数
3,165 次查看
javier1
I get the same problem, but i use a custom board with PK60N512VMD100.
Write memory failed: address 0x0.
Expected value: 0x1fff7598
Have you solved your problem?
Help, please.
thanks to all!!
3,165 次查看
geochrist
I remember the problem being a bad chip.  Needed a new one.
3,165 次查看
javier1
Are you sure? My chip is a BGA package and can´t quit and put!!
The K60 is new from arrow, and i have tested with 2 custom boards...
3,165 次查看
geochrist
Maybe your board is bad, then.  Sorry, but it was a while ago and I'm just repeating what my engineer told me.
Regards.
3,165 次查看
javier1
Can you tell me the mask of your ICs?
Thanks again.
3,165 次查看
geochrist
I'm sorry but I don't have that information.  I am not working on that project anymore and no longer have access to the data.
Best wishes to you.
