GPIO status between Power-on and POR
1,410 次查看
masahirokiniwa
Could tell me the GPIO status of Kinetis K27 between Power-on and POR?
I care that K27 output a pulse or drive to high/low during power-up sequence.
During POR, it will be status as Table 11-2 at reference manual. But I couldn't find the status between power-on and POR.
M.Kiniwa
4 回复数
1,155 次查看
masahirokiniwa
Hi Robin,
Thank you for your confirmation.
I see your test result. But I need this status about all GPIO and a guaranty of this result.
Could you confirm all GPIO and check MCU design?
M.Kiniwa
1,155 次查看
Robin_Shen
Hi Masahiro,
Sorry for the late reply!
Would you please attach waveform that you found? And tell us which pin are you testing.
I don't have K27 MCU. Maybe I can check it on FRDM-K28F.
Robin
1,155 次查看
masahirokiniwa
Hi Robin,
I didn't test it, yet. And it didn't occur a problem on FRDM-K28F.
But I must know the status between Power-on and POR for preventing a problem to the application.
Could you tell me its status by test or MCU design?
M.Kiniwa
1,155 次查看
Robin_Shen
The K28 and K27 have same Mask Set, so I think the status of GPIO between Power-on and POR should be same too.
I observe the waveform of PTA30 pin on FRDM-K28F by oscilloscope, did not find pulse or drive to high.
Robin
