GPIO Pin's State on power-up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I'm designing a system with K64 MCU
My question regarding all GPIO's state on power-up :
1. The GPIO's state on boot is output or input ? if so, is it PU/PD/HiZ ?
2. What doe's it mean that the default function of a GPIOs is "DISABLED" ?
Looking at the reference manual - http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf
Page 244, chapter 10.2.2 Port control and interrupt summary
"Pull enable at reset - Disabled" - so i can understand from that that the GPIO is defined as Input Hi-Z ?
Please clarify this issue for me
Thanks & Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Eduard Razumovsky:
Mark's response is completely correct. You should look at the Default column in the pinout table.
DISABLED indicates no function after reset, so that is High-Impedance.
Pins with an analog MUX option will be connected by default after reset to their corresponding analog module.
Regards!
Jorge Gonzalez
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Okay, but what about this case on my MK02Z?
powering up issue on MKE02Z GPIO
On power-up PTB4 seems to follow the VCC ramp and after PE initialization this is set as a digital output with zero value.
regards,
gaston
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No pins are GPIOs outputs after reset.
If their pull-up is disabled at reset it means that there is no pull-up or pull-down connected. [Only the pins that default to JTAg use have pull-ups or downs eabled out of reset].
Some pins default to peripheral functions (see 10.3.1) and not GPIO.
If disabled out of reset, it means that there is no connected default function - the pin is not GPIO input without first setting the GPIO Mux function (Alt 1).
Mark
Kinetis: µTasker Kinetis support
K64: µTasker Kinetis FRDM-K64F support / µTasker Kinetis TWR-K64F120M support / µTasker Kinetis TWR-K65F180M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
