FreeRTOS can't be included on MKV31F256VLH12 SDK
1,198 次查看
talledo
Based on SRARM/Flash requirements, this MCU should be able to handle FreeRTOS as NXP advertised but when trying to build a SDK, that option is not available, it suggests to try the FDRMKV31F MCU which is MKV31F512VLL12.
Any ideas how to get the SDK with FreeRTOS?
标记 (1)
1,132 次查看
talledo
There is an information about not being supported. If I select the previous SDK, that warning is gone. Should I be concerned?
1,132 次查看
danielchen
Hi Jean
MK31F256VLL12 can support FreeRTOS, but there is an issue in SDK2.6. FreeRTOS has ported to Frdmkv31f and Twr board. but not ported to processor MK31F256VLL12.  This issue is fixed in SDK2.7, and will be released before the end of this year.  You can start with SDK_2.6_Frdmkv31f.  Or port by yourself.   I will notify you when the release is ready. Sorry for the inconvenience that maybe caused.
1,132 次查看
danielchen
Hi Jean:
I tried this on my side, Amazon-FreeRTOS can be selected.
