Failing to connect to JLINK Probe
Devyy
Hello everyone,
I'm currently on a intership in a company where I'm supposed to program on a TWR-KV58F220M.
To achieve this, i'm using a JLINK probe made by Segger. I'm using MCU Xpresso.
My problem is that, when I try to start debugging, MCU Xpresso fails to connect to the probe.
The debug configuration is working on others computers, just not working with mine.
The error message that is given to me is right below :
And the console shows :
I tried to find a solution but didn't succeed.
If you have any idea, feel free to help me !
I can give more informations if needed.
Thank you in advance everyone,
Devyy
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
