Failed to download mbedTLS Library for Kinetis K61
r_m_keni
I have tried downloading mbedTLS library from the given link, but the download failed with following error
Link: https://www.nxp.com/design/designs/software-development-kit-for-kinetis-mcus:KINETIS-SDK
If anyone have another link please let me know.
r_m_keni
We did not find SDK for Kinetis K61 series. Can we use any other controller from MK6xx series as we will be using only the mbedtls library from it, which I suppose shall be common ?
RaRo
Hello @r_m_keni,
Please try using the SDK for K60. In fact, as you point out, the mbedTLS library shouldn't have any difference between the K60/61 series.
Best regards, Raul.
RaRo
Hello @r_m_keni,
You could try downloading it from here: Welcome | MCUXpresso SDK Builder.
Please follow the next steps:
  • Click on Select Development Board
  • Search for the board or microcontroller you need, select it and click on Build MCUXpresso SDK
  • Choose your OS and IDE you are using, and click on the mbedTLS library for including it on the download. Finally click on Download SDK.
  • After download it you can search for the mbedTLS library in middleware
Best regards, Raul.
