FRDM-KL25Z and multiple hall sensors
1,647件の閲覧回数
rajakumar
Hi All,
Requirement :
Count the pulses generated by hall sensor inside a flow meter.  The hall sensor produces around 330 pulse / second.  There would be around 6-10 flow meters connected to a circuit for calculating the total consumption.
Is frdm-kl25z my best bet to start this project or is there any other better alternative available.
I am thinking of using the GPIO pins in interrupt mode to count the pulse.  Can multiple interrupts work without data loss parallely. Can the MKL25Z128VLK4 MCU handle this.
ラベル(2)
1,499件の閲覧回数
Paul_Tian
Hi, Rejakumar
Yes, You can use MKL25Z128VLK4(TPM function/GPIO function) in your application.
Hope my reply can help you.
Best Regards
Paul
1,499件の閲覧回数
rajakumar
Hi Zhe Tian,
Thanks for help.
Just ordered the FRDM-KL25Z kit.  Will update once I have it working.
Rajakumar.S
