code is attached. Kindly help
Original Attachment has been moved to: main.c.zip
Original Attachment has been moved to: UART.c.zip
Solved! Go to Solution.
Hi Lajitha,
Sorry for the late reply!
Please check the circuit of FRDM-KE06Z, these resistances are not placed by default.
Robin
Thanks Robin. It was a hardware issue. the problem has been solved now
Hi Lajitha,
Robin
