FRDM KE04Z won't exit bootloader mode
1,117 次查看
andrewwenger
Hi I am really new with FRDM boards and am working in a group for a university project. I am following the quick start guide for the FRDM KE04Z and am in the open SDA bootloader mode. I have followed the instructions but when I disconnect the board and plug it back in it still comes up as bootloader drive vs the FRDM drive. Can anyone tell me how to fix this?
935 次查看
mjbcswitzerland
Specialist V
Andrew
If the board shows up as bootloader it means that either the RESET switch is being held down on power up or there is no code valid loaded.
If you loaded debugger code to it check the "status" file which will indicate whether the loading was sucessful or not (immediately after loading). If it failed or an invalid file was loaded it will stay in the bootloader mode.
Mark
Kinetis: µTasker Kinetis support
KE: µTasker FRDM-KE02Z support  / µTasker FRDM-KE02Z40M support  / µTasker Kinetis support  / µTasker FRDM-KE06Z support
For the complete "out-of-the-box" Kinetis experience and faster time to market
