I cannot download the SDK examples from MCUXpresso to the FRDM-K64F evaluation board consistently, I need to plug in and out the USB several times to make it go through.
I always have the following error:
The red LED is always on near the green LED when the issue happens.
I just use the SDK example and debug from the MCUXpresso, nothing else.
Could somebody suggest what might happen here?
Thanks a lot for your help
Ni
已解决! 转到解答。
Hi @niz
It might be that the middleware in your board is outdated. Please look through this guide and update the OpenSDA version;
After this, try installing the SDK again onto your board. If this doesn't work, please tell me to search alternatives.
Best regards, Julian
Hi @niz
Hello Julian
I got another FREEDOM64F board, and after doing the same updating the SDK process, my PC can detect the FRDM_K64FD in the Portable Devices, however, the red light is always on and the MCUXpresso cannot detect the SWD, is there any way to take care of that issue?
Hi @niz,
The constant red LED means your boards is constantly resetting. Here is a similar case you can consult for the solution: Solved: New FRDM-K64F resets after 30 seconds - NXP Community
Hope it helps!
