Hi everyone,
we are using two different versions (D1 and E3) of the FRDM-K64.
Booth are loaded with OpenSDA V2 and we use the KDS 3.
But with the E3 the usb-connection/debugging with the desktop is not stable. Sometimes it runs for 20 minutes, sometimes it hangs after 3 steps.
Does anybode else has such problems?
解決済! 解決策の投稿を見る。
Hello intertronic,
please, have you tried to reload open sda firmware on the FRDM-K64F ?
On my side is running FRDM-K64F - schematic E3 revision without some problems.
In other case, is it possible for you to attach screen of the error?
Iva
Hello intertronic,
Iva
Hello Iva,
Problem seems to be solved.
The problem was, that the USB seems to break down. We used the OpenSDA
version 2 with a version from last year which was working with the old
FRDM-K64F. further we used the version 2015-04-23 which doesn't work. We
found a new version 2015-06-11 which is working with the new FRDM-K64F...
Thanks, Josef
Am 14.07.2015 15:02, schrieb ivadorazinova:
Freescale Community
<http://jiveon.jivesoftware.com/mpss/c/owA/PDcDAA/t.1op/Wd4oS6ZkS1a4b3kVkvPiiA/h0/eqhG5v9o4WV1pCmWaB03cUjBPgRj-2F3GoJUaXSZ409bQ-3D>
FRDM-K64F Revision E3 not working
reply from Iva Dorazinova
<http://jiveon.jivesoftware.com/mpss/c/owA/PDcDAA/t.1op/Wd4oS6ZkS1a4b3kVkvPiiA/h1/eqhG5v9o4WV1pCmWaB03cUjBPgRj-2F3GoJUaXSZ409bTV2H6l88qkV2k9D4HQo1uUWCFUeozZRGYbPu5sDFrZDsGKUic9H-2BaheNxdnhWEhJU-3D>
in /Kinetis Microcontrollers/ - View the full discussion
<http://jiveon.jivesoftware.com/mpss/c/owA/PDcDAA/t.1op/Wd4oS6ZkS1a4b3kVkvPiiA/h2/eqhG5v9o4WV1pCmWaB03cUjBPgRj-2F3GoJUaXSZ409bSDdtwb8JVqMb8Sn4bht2-2FbBJDAxvikVF8Q-2F1HzqGadvABOgc1joeLdeDal0dJRJDw-3D>
