FRDM-K22F, what part number fits in the micro SD footprint?
已解决
跳至解决方案
1,156 次查看
robotjosh
Its very shallow for a micro sd slot and did not see anything that looked like it would fit on digikey.  Other dev kits from freescale use a different slot.  I do not see any clues in the UG or schematic and do not see any hardware layout or bom available for download.  Please let me know what this part is or what document contains this information.
1 解答
1,026 次查看
Hui_Ma
Hi Josh,
The SD Card slot part number is Molex 1050270001, you could get more detailed info from below link:
http://www.molex.com/molex/products/datasheet.jsp?part=active/1050270001_MEMORY_CARD_SOCKET.xml&chan...
And below is Digikey related purchase link:
1050270001 Molex Inc | WM6825DKR-ND | DigiKey
Wish it helps.
best regards
Ma Hui
在原帖中查看解决方案
1 回复
1,027 次查看
Hui_Ma
Hi Josh,
Wish it helps.
best regards
Ma Hui
