I'm interested about flash my freedom board with an external tool, instead of internal Eclipse Flash programmer. Is there any way to do it? (OS is Linux Ubuntu)
已解决! 转到解答。
Hi Darnai Adam,
I think the JLink tool is good choice.
And you can learn the more information about the Eclipse with GDB through the thread below.
https://mcuoneclipse.com/2015/03/25/command-line-programming-and-debugging-with-gdb/
Ping
Hi Darnai Adam,
To be honest, I'm not very clear the meaning of the internal Eclipse Flash programmer you mentioned above.
So can you explain it again? And do you want some debug tools?
Ping
Yes, thats what I meant. I'd like to use a programmer that communicates with GDB server and than flash my application through the USB connection to the Processor, without any IDE, for example KDS. I read that there are solutions via terminal, but I prefer an application that provide a GUI for the user.
Hi Darnai Adam,
Ping
