Ethernet question
Ethernet question
1,326 次查看
jambriz
If I'm using RTCS for sending socket, is activated CRC by default?
Thank you for your help
:smileywink:
1,071 次查看
PaoloRenzo
Yes! :smileyhappy: Ethernet outgoing packets will have CRC appended in hardware. For IP and other inner protocols, these are calculated by RTCS
1,072 次查看
PaoloRenzo
1,071 次查看
jambriz
Gracias Paolo!
:smileywink:
Thank you!
