Ethernet controller & SD at about 30cm
997 次查看
Microfelix
hello
I'm doing a project where I use the ethernet and the SD with the K60.
I was wondering if you can place both the Ethernet controller that SD at about 30cm from the microcontroller via a flat cable.
There are no contraindications and has already been tested?
thanks
Maurizio
838 次查看
B_Sandor
Maurizio!
Could you help me to design an ethernet connect for K60?
I didn't find example how do I connect  K60 to RJ45.
Could you send me a schematic for it? (bodoczs@t-online.hu)
Thx.
