Erase Flash Action
Erase Flash Action
2,030 次查看
victorheca
 When I debug my firmware on MCU of  MKL25Z128 using PnE. It always failed and hang MCUXpress IDE software. IDE found PnE device and PnE works well under Code Warrior.  Is there anything wrong with my settings? Many thanks.
5 回复数
2,013 次查看
victorheca
Hi, Erich,
I managed to make the debugger works now. Thanks for your help.
2,017 次查看
victorheca
Hi, Erich,
  Here is my project. Many Thanks to your kind help.
1,990 次查看
ErichStyger
Specialist I
I noticed that in your project you have the wrong SDK/MCU assigned?
This can cause all kind of problems, so I suggest that you change the SDK to the KL25Z one.
2,029 次查看
victorheca
Sorry my debugger is PE Micro.
2,025 次查看
ErichStyger
Specialist I
Can you share your project?
