Does Freescale has Serial Bootloader (AN2295 v.10.0.18.0) Windows GUI Visual Studio project download?
1,536 次查看
jackylau
I'm trying to get serial bootloader working in a K60 processor - after some search, I've figured the device bootloader and got the bootloader to work with windows host version 10.0.18.0 (protocol 9).
However, the an2295sw.zip file I download from previous discussion contains only the executable. If there in the Freescale site where I can also download the host code version 10.0.18.0 (I heard that it is a visual studio project) for modification?
Thank you!
1,201 次查看
Hui_Ma
Please try attached AN2295 master software.
Wish it helps.
best regards,
Ma Hui
4 回复数
1,201 次查看
Hui_Ma
Please download AN2295SW from here, which includes Serial Bootloader master software source code.
Wish it helps.
Ma Hui
1,201 次查看
jackylau
Thanks for your response~!
However after opening the program, I notice the version # is 10.0.13. I'm looking for the code with version 10.0.18.
Reason: Apparently, the K60 serial bootloader provided only works with version 10.0.18 (protocol 9 apparently).
Here's Freescale's link to the 10.0.18 executable:
AN2295 protocol version 9
Please let me know if the source code for 10.0.18 exist somewhere~!
Thank you!
1,202 次查看
Hui_Ma
Wish it helps.
best regards,
Ma Hui
1,201 次查看
Hui_Ma
Hi Jacky,
I will check with AN2295 author about related master software source code (Rev. 10.0.18).
I will let you know when there with any feedback.
Thank you for the patience.
best regards,
Ma Hui
