DSC 56F8300E versus Kinetis KV
1,182件の閲覧回数
miroslavmartise
Hello everybody,
I am going to construct a new device, which will be used as AC induction motor controller. I have worked with DSC 56F8300E(X) recently, but nowadays I am ruminating on Kinetis KV platform. Which platform is according to you better for new development? What is your opinion?
Thank you very much for your replies.
2 返答(返信)
1,020件の閲覧回数
miroslavmartise
thank you for your advice. So, I have decided to use Kinetis V based platform for my current project regarding ACIMs. I believe, it will work fine...
Nice day,
Miroslav
1,020件の閲覧回数
xiangjun_rong
I do not know if you use FOC or VVVF algorithms to control a ACIM, anyway, I suggest you use KV family to control ACIM.
We have the library for the motor control based on Cortex-M0, Cortex-M4 and Cortex-M7, for example Clark/park transformation,  PID, SVPWM, bus voltage decolping...
For example, most of peripherals of KV5x are the same as that of DSC.
This is KV website:
Kinetis Low Power 32-bit Microcontrollers (MCUs) based on ARM® Cortex®-M Cores|NXP
Hope it can help you
XiangJun Rong
