Could you please create a master list of Kinetis uCs that support flash swap?
1,460 次查看
jimmorash
This information is extremely hard to find, especially when choosing between a large number of different parts to start a new design.
I would prefer to use the EA series, but it looks like none of them have dual bank flash. How about the K10 series?
3 回复数
1,350 次查看
kerryzhou
Hi  Jim Morash,
      KEA don't have the flash swap function, but Freescale kinetis K series 100Mhz and 120Mhz have this function.
      K10 100Mhz have flash swap function, eg.MK10DN512VLL10
Wish it helps you!
If you still have question, please contact me!
Jingjing
1,350 次查看
jimmorash
Thanks. Where is this indicated in the data sheet? Can you add a parametric search column for this feature?
Can you confirm that the MK10DN512VLK10 (80-pin package) also supports flash swap?
Also, are these products recommended for new designs?
1,350 次查看
kerryzhou
Hi Jim Morash,
    It indicated in the reference manual, the link is :
http://cache.freescale.com/files/32bit/doc/ref_manual/K10P81M100SF2V2RM.pdf?fasp=1&WT_TYPE=Reference...
Page 628, 29.4.1 Program Flash Memory Swap
Wish it helps you!
Jingjing
