Configuring N25q_256 to QuadSPI mode in K82F
837 次查看
bvsrkrishnarao
I am having problem in configuring the N25Q256A flash from micron that comes with TWR-POS-K81. I have tried
1. Clearing bit 3 of the  Nonvolatile Configuration Register.
2. Clearing bit 7 of the Enhanced Volatile configuration register.
But both the methods doesn't seem to work.
Reading both the registers after setting those bits again give me the old values. I set the WEL in the status reg before programming these two registers.
If any sample code to initialize the N25Q256A flash to QuadSPI will be greatly appreciated.
Thanks a lot
751 次查看
Hui_Ma
Please check attached QuadSPI Initialization and test code for your reference.
Wish it helps.
Ma Hui
